Показатели TPMS (датчики давления)
+5
Сообщениеот a.gribenko » 10 янв 2012, 00:13
коротко - чтобы сбросить датчики - выключите / включите зажигание и проедьте со скоростью более 25км/ч более чем 5 минут.
Reading TPMS codes and clearing them
There is a simple procedure to perform a self diagnostic and clear the codes.
1) Turn IGN switch to ON.
2) Locate the TPMS warning check connector. It is a single loose wire with a connector located under the dash next to the steering column. It may be bundled with the OBDII diagnostic connector.
3) Using a suitable piece of bare wire inserted into the connector (a paperclip will do), momentarily ground the wire to the chassis.
NOTE: If you are uncomfortable doing this, then don't. You could damage your vehicle if the wrong wire is grounded.
4) The TPMS low tire pressure warning light will blink error codes as follows:
5sec. ON - 5sec. OFF
Long (1 sec) blink = First digit (2 blinks = 2)
Short (0.2 sec) blink = Second digit (ie 3 short blinks = 3)
There is a 2 second pause between multiple codes.The cycle will keep repeating starting with 5sec. ON
Codes:
15 - Front LH tire pressure drops to 26 psi or less.
16 - Front RH tire pressure drops to 26 psi or less.
17 - Rear RH tire pressure drops to 26 psi or less.
18 - Rear LH tire pressure drops to 26 psi or less.
21 - Data from front LH transmitter can not be receive.
22 - Data from front RH transmitter can not be receive.
23 - Data from Rear RH transmitter can not be receive.
24 - Data from Rear LH transmitter can not be receive.
31 - Checksum data from front LH transmitter is malfunctioning.
32 - Checksum data from front RH transmitter is malfunctioning.
33 - Checksum data from rear RH transmitter is malfunctioning.
34 - Checksum data from rear RH transmitter is malfunctioning.
5 short blinks - System is OK.
5) To clear the codes, turn the ignition OFF.
6) Drive 5 min above 16mph (25km/h) to see if the problem reoccurs.
This procedure does not guarantee you won't get the blinking TPMS warning again. If the problem reoccurs, the warning light will turn back ON.
a.gribenko Offline
Вернуться в Rogue
