Кто в английском силен? Можете помочь?
Сообщениеот Berk » 15 фев 2010, 18:32
надо перевести пару абзацев
1. Shortest model sight yet! This sight is smaller than the former N-cell battery sight (511/551) and runs on a single 123 battery. It also has a longer battery life than the N-cell style sights. Smaller,lighter and always fast with three reticle options. With the new single battery configuration, the XPS allows more rail space than ever, leaving more room for rear iron sights or NV mount.
* Single transverse 123 battery to reduce sight length
* Shortened base only requires at most 2 3/4 inch of rail space compared to the 4 inch N battery sights
* Battery cap and latch are eliminated and replaced with a simple O-ring, tethered cap; better sealing is achieved
* Battery compartment is now separated from the base to allow it to hover over the delta ring of the rifle
* Average battery life at brightness level 12 is roughly 500-600 hours, 3X battery life of N cell sights
* Three reticle options: 0- 65MOA circle with 1 MOA aiming dot, 1-single 1MOA aiming dot, 2-65MOA circle with two 1MOA aiming dots
* Available in Night Vision (XPS3) and non- Night Vision (XPS2) versions. The numbers reflect the number of the buttons on the back of the sight.
2. NSN 1240-01-554-4488 GSA Contract: GS-07F-0182L Cage Code: 1MLU1 Duns: 87 768 5933
The Model 512 is the most popular model HWS. This tactical optic is perfect for agencies that want the best in CQB speed and versatility, without the need for night vision compatibility.
* AA Battery model (supports Lithium and Alkaline)
* 65 MOA circle with 1 MOA aiming dot reticle pattern
* Includes rugged aluminum hood assembly and knobbed, tool-less mounting bolt
* Interfaces to 1" Picatinny (MIL-STD-1913) rail
3. Grid Pattern in a long-sleeved shirt made from Polartec Power Dry fabric worn for extra warmth. Wicks away moisture quickly and dries fast. An inserted side panel of Polartec X-Static fabric enhances fit and flexibility.
4. Grid Pattern in a long pant made from Polartec Power Dry fabric warn for extra warmth. Wicks away moisture quickly and dries fast. An insterted side panel of Polartec X-static fabric enhances fit and flexibility
Re: Кто в английском силен? Можете помочь?
Сообщениеот fly » 15 фев 2010, 18:45
Клетчатая рубаха с длинным рукавом, сделана из ткани "Polartec Power Dry" (морозоустойчивая синтетика) подоедваемая для дополнительной теплоты. Отводит пот и высыхает быстро. Вставляющаяся боковая вставка из ткани "Polartec X-Static" улучшает прилегание и добавляет эластичности..
Как то так. Берк - шо это? термобелье?
fly Offline
Сообщениеот Berk » 15 фев 2010, 18:46
да, две позиции термобелье и две позиции снайперские прицелы
Сообщениеот fly » 15 фев 2010, 18:47
По ходу тот же смысл,тока про штаны.
Тока я не до конца понимаю что такое Grid Pattern - я было подумал, что это ткань в клеточку..
fly Offline
Сообщениеот Петрович » 15 фев 2010, 18:48
http://www.perevodslov.ru
http://www.multitran.ru
попробуй поюзать, мне неоднократно помогали.
Первый - переводчик фраз (предложений), второй - переводит слова и устойчивые словосочетания.
Петрович Offline
Сообщениеот fly » 15 фев 2010, 18:48
Про прицелы - я не силен - там специфических слов много.
Если никто не поможет, я попозже переведу со словарем
fly Offline
Сообщениеот Lalyque » 15 фев 2010, 18:49
это может быть название (или термин)
Lalyque Offline
Сообщениеот Berk » 15 фев 2010, 18:49
Петрович оно так переводит, что я уже и не понимаю о чем речь. Но все равно спасибо (улыбка)
Сообщениеот fly » 15 фев 2010, 20:13
2. NSN 1240-01-554-4488 GSA Contract: GS-07F-0182L Cage Code: 1MLU1 Duns: 87 768 5933 - Кахбе понятно
512 модель - самая популярная из HWS. Этот оптический прицел идеален для команд, желающих быть лучшими в ЦКБ (ггг -прим переводчика) (CQB - видимо в ближнем бою), без потребности в ночном видении.
*Работает на AA батарейках
*Прицельная марка: Круг (65 МОА) с точкой (1 МОА)
*Имеет жесткую (шероховатую?) алюминевую монтажную планку и выпуклый (tool-less - я ХЗ)  крепежный болт
*Крепление совпадает с рейкой стандарта Picatinny (MIL-STD-1913)
Наверное это оно?
fly Offline
Вернуться в Розмови про все
